Porsche GT2 Vs. Z06 in a drag competition
DrOlds King of the Road29.03.08 01:51
DrOlds
Chevrolet Corvette Z06
In Detail
submitted by Richard Owen
price $65 800 USD
engine Cast Aluminum LS7 V8 w/Dry Sump Lubrication
position Front Longitudinal
valvetrain OHV, 2 Valves w/Cyl
fuel feed Sequential Fuel Injection
displacement 7011 cc / 427.8 cu in
bore 104.8 mm / 4.13 in
stroke 101.6 mm / 4.0 in
compression 11.0:1
power 372.9 kw / 500 bhp @ 6200 rpm
hp per litre 71.33 bhp per litre
bhp/weight 352.18 bhp per weight
torque 644.01 nm / 475 ft lbs @ 4800 rpm
redline 7000
drive wheels RWD w/Electronic Traction Control
body / frame Composite Body Panels over Hydroformed Steel Frame w/Aluminum & Magnesium Structural Components
front tires 275/35ZR18
rear tires 325/30ZR19
front brakes Vented & Cross Drilled Rotors w/6 Piston Calipers, ABS
f brake size 356 mm / 14 in
rear brakes Vented & Cross Drilled Rotors w/4 Piston Calipers, ABS
r brake size 340 mm / 13.4 in
front wheels F 45.7 x 24.1 cm / 18.0 x 9.5 in
rear wheels R 48.3 x 30.5 cm / 19 x 12 in
front tire size 275/35ZR18
rear tire size 325/30ZR19
steering Rack & Pinion w/Speed Sensitive Power Assist
f suspension Wishbones w/Upper & Lower Control Arms, Transverse Composite Leaf Spring, Monotube Shock Absorbers
r suspension Wishbones w/Upper & Lower Control Arms, Transverse Composite Leaf Spring, Monotube Shock Absorbers
weight 1420 kg / 3130 lbs
wheelbase 2686 mm / 105.7 in
front track 1577 mm / 62.1 in
rear track 1542 mm / 60.7 in
length 4435 mm / 174.6 in
width 1930 mm / 76.0 in
height 1246 mm / 49.1 in
transmission Tremec M6 6-Speed Manual
gear ratios 2.97:1, 2.07:1, 1.43:1, 1.00:1, 0.71:1, 0.57:1
final drive 3.42:1
top speed 318.7 kph / 198 mph
0 - 60 mph 3.6 seconds
0 - 100 mph 8.3 seconds
0 - 1/4 mile 12 seconds
epa city/hwy 21 mpg
VS.
Porsche GT2
In Detail
price $191,700 USD
engine Aluminum M96/70S Flat-6
position Rear Longitudinal
aspiration Borg Warner Variable Turbine Geometry (VTG) Twin Turbos
valvetrain DOHC, 4 Valves per Cy w/Expansion Intake
fuel feed Bosch Motronic DME 7.8 Fuel injection
displacement 3596 cc / 219.4 cu in
bore 100 mm / 3.94 in
stroke 76.4 mm / 3.01 in
compression 9.0:1
power 395.2 kw / 530 bhp @ 6500 rpm
hp per litre 147.39 bhp per litre
bhp/weight 368.06 bhp per weight
torque 684.69 nm / 505 ft lbs @ 2200-4500 rpm
drive wheels RWD w/PSM, LSD
body / frame Unit Steel
front tires 235/35VR19
rear tires 325/30VR19
front brakes PCCB Ceramic Discs w/Brembro 6-Piston Calipers, ABS
f brake size 381 mm / 15 in
rear brakes PCCB Ceramic Discs w/Brembro 4-Piston Calipers, ABS
r brake size 350 mm / 13.8 in
front wheels F 48.3 x 21.6 cm / 19 x 8.5 in
front tire size 235/35VR19
rear tire size 325/30VR19
f suspension MacPherson Struts w/Coil Springs,Active Dampers
r suspension Multi-Link w/Active Dampers
weight 1440 kg / 3175 lbs
wheelbase 2350 mm / 92.5 in
front track 1514 mm / 59.6 in
rear track 1549 mm / 61 in
length 4468 mm / 175.9 in
width 1852 mm / 72.9 in
height 1481 mm / 58.3 in
transmission 6-Speed Manual
final drive 3.44:1
top speed 328.3 kph / 204.0 mph
0 - 60 mph 3.4 seconds
0 - 100 mph 7.4 seconds
Und hier das Video
Re@lity King of the Road29.03.08 09:54
Re@lity
Perth / Western Australia
lol ich glaub nich das der porsche was reissen kann ....
My Rides:
'87 Ferrari 328 GTS
Rusty Site Admin29.03.08 14:58
tjoa....hat wohl die corvette gegen den gt2 den kürzeren gezogen. aber chevrolet hat ja noch einen joker, die zr1! Very Happy
man sollte bei solchen vergleichen auch nicht eins vergessen, der porsche kostet mal locker 100.000 $ mehr als die vette. Wink
Re@lity King of the Road29.03.08 17:55
Re@lity
jau das stimmt der GT2 soll mal gegen die ZR1 fahren da zieht er den kuerzeren muhahahahahaha
My Rides:
'87 Ferrari 328 GTS
